2000 GT Zaskar LE XS Frame
steve_d
I've got a hold of a 2000 Zaskar LE XS, about 15", almost original spec, a few things have been changed such as forks, front v-brakes, seatpost, saddle, grips. Due to the changes and frame size I was considering breaking it, I've an idea what the parts are worth but not much regarding the frame, I'd be interested in suggestions regarding the frames value, thanks.
Steve
It’s a 12.5 size
Usually a Zaskar frame if this era is worth very little. However the size will sell this. I had a silver 2000 ish 12.5 and the frame sold instantly for £150 as people build them for their kids.
Worth more parted out though I'd appreciate input as to what the bike's worth as is. Spec is-
Forks- 2002 Marzocchi Bomber MXR Air
Cranks- XTR M952, middle ring needs replacing
Wheels- Mavic XC717 disc ready, WTB Momentum hub to front, XT M755 hub to rear
Shifters- XTR M952 3x9
Brake levers- Avid Speed Dial 1.9L
V-brakes- front LX M570, rear Avid Speed Dial 25
Derailleurs- XTR M952
Cassette- XTR M952
Stem- Azonic OCR
bars- Azonic O'Neal flat
You’d likely struggle to get £300 as a full bike.
It’s a donor bike for someone and you’ve gotta leave room for broken bits and make it worth it.
Thanks for the reply, even though I've gone over the bike to make sure everything's working, except the middle chainring, and done an initial service, I'll make the effort to break the bike
For starters, that's a very rare frame, perhaps so rare that a value will be hard to determine.
Given that you are in [Europe], there is an overwhelming stigma that a retro bike frame is sized to fit an individual; ie the top tube must intersect the seattube immediately under the poop chute. That drives down the value in Europe as this frame, in theory, is kid-size. Someone will only want it for their growing toddler.
In the US a sloping top tube with a long seatpost is desirable. In the US that would be a very coveted frame. The industry standard way back when was that the rider would drop the seatpost into the frame to freely move around on the bike.
Size guides in the brochures would disagree. Unless of course it’s trials or a jump bike but then in theory geometry changes for the reach.
