150mm cranks.
I have gone down from the common sizes of 175 and 172.5 ,that i used as a teen and young adult , to 170 and then 165 and after that 160. This i did with lots of months in between. I have now down to 140.
There is an awful lot of carp on the internet about short cranks due to alot of misunderstanding, of mechanical principles, and a healthy dose of old wives tales with a good topping of troll jibber jabber.
I have gone short because of knee injuries and scrunching them up, too much, at the top of the stroke doesn't feel nice. Another knee preservation thing(for my knees at least) is i have a position where my knees are way ahead of the pedals at the 3 o'clock position(kind of what a modern time trial position is). I am also using Osymetric chainrings which started as an experiment, because they might also help knees, and when i saw some super cheap i thought why not give 'em a go?, and now i am a convert.
Anyway....things felt very good(not quite 100% though), but switching to the 140 cranks has brought it all together. I have been able to use bigger gears at a higher cadence, for one thing, and the biggest difference i have noticed is how less out of breath i am, at particular points, on some regular routes.
The negative, which is the only time i think the lever argument can be used, is when you find yourself terribly overgeared for a hill and you are pretty much at a slow walking pace. Then i noticed the shorter cranks, but that is easily sorted by fitting a larger cog on the back. Depends on a few things but approximately a 4 to 8 tooth jump would need to be considered, if you live amongst steep hills. So; 28 to 32/34/36 for example.
So, for my physiology, it all works very well. It still feels a bit odd, for a while as i have a 'dad bike' that is presently more conventional for popping around the block, and i have only done several rides in the 140's, but once i get into a ride it has been eye opening. Tbh i have been a bit stunned , so far, by the rise in capability.
It is all very personal. Due to all the different shapes and sizes of us humans, how we like to feel on a bike, what attitudes we have etc and it is very possible that none of my setup , or even part of it, will work for someone else.
Going by internet/magazine reviews/ experiments and research papers is usually, in my opinion, a waste of time because the tendancy, for most, is to only swap item A for item B with no thought that the swap might require a change in position, for example.
A good example of this is with these Osymetric rings. I wonder if all of the naysayers had pushed their saddles forward then more might have gotten on with them ,positively , as i think that might be what you have to do if you are going to use them. Same goes for extreme oval rings, like Rotor XL's, with the different positions you can put them into the stroke, but it may just be my physiology.
Another thing that always crops up is along the lines of, "well, if xyz is so much better then why don't all the pro's use them" and this is spouted by trolls and people who aren't thinking.
Pro cyclists are often at the mercy of sponsors and budgets , for what they can use, and alot of them just haven't got the time to experiment and certainly can't risk the potential for injury by trying some stuff out be it saddles, crank lengths etc. If a pro did find something that felt great , and the numbers looked good , it still might be impossible to get it made, or use a non-sponsored item. Might be differnt for a really big name, but for most of them who will never win a race in the career things will not change.
I have felt some big changes in how muscles work, with my experiments, and it takes time for things to settle in. I could imagine that a pro, who has ridden a particular setup for decades and does 10,000kms a year, could do themselves a costly mischief so are a few watts even worth the risk?
I think this is why Pog has been going shorter in steps and maybe JV has been doing the same, behind the scenes, since his last big event in 2024?
I find the cycling part of the Ironman triathlete world is really worth keeping an eye on. They have always been more open to innovation and experimenting with stuff and use alot of niche items. Lots of reasons for this , but mainly it isn't a sport with 100+ years of 'the old ways' and they need to preserve muscles for the long run, that follows the long bike section.
I say give it a go, if you are curious. There are second hand options and new if you look at junior BMX kit. Pick a make that has cranks in various lengths and don't be put off by the word junior. The short cranks will look exactly like the longer options, but are just shorter.
There are always cheapo short cranks for the BSO market ,on ebay, but the chainrings can't be swapped out. It will still give you something to try, though.
One thing to plan in, if anyone reading this does experiment, is be prepared to have to buy a few bottom brackets axle lengths due to the big differnces you can get between cranks(chainline, chainstay clearance etc).
I am all square taper so that is cheap and easy to play with. I have no idea what problems will occur and even what goes on with all the other standards and options, on modern bikes.
My disadvantage is likely cost to my wallet. All the current recent publicity has this morning resulted in my wife wandering around with a tape measuring all her bikes cranks.
She's currently googling away looking at 165/160 options.
I could go for 165s. As a yoof I raced the steep banked track on wooden boards on a very short wheelbase Bob Jackson. They certainly spin up a lot faster and it's easier to keep a high cadence, not sure what advantages you would get over a distance. Most of my races were over in 90 seconds 🤣😎
I'm very interested by what @Frankenorange says above. I've got 160mm cranks on my gravel fixie (for reasons of ground clearance). I expected to find I lacked leverage but I really like them. I think I'm going to try shorter cranks on my regular cross bike too.
A friend of mine who runs a cyclist coaching company and does a lot of wind tunnel testing with riders said that shorter cranks are also more aero.
Pedalling around corners , i would've coasted around before , is something i am getting my head around. I don't think you ever forget pedal strikes , and ending up on the deck , so some re-training of the mind is in order. Silly really because if i put the crank down and lean the bike over, so a pedal touches tarmac , the lean angle is ridiculous. Maybe i could do what that MotoGP riders do and scrape my shoulder and helmet through the bends! :)
I think the aero thing is two fold. You can get a flatter back without thighs interacting with the torso and maybe the air must flow better in that gap. The latter is my own guess.
Like i said above; easier breathing is the thing i have noticed most. I have no idea if it is just a case of being more efficient, or my diaphragm is not getting crushed , as much , but i will take it whatever the reason is. Maybe a bit of both.
There is another positive. I use very narrow bars and with the super short cranks i can stand on the pedals and the bike doesn't steer about on each downstroke.
I think the steering about thing is a sign of poor core strength as track sprinters use really narrow bars and they sprint dead straight. Anyway...it is improved before the six pack has shown up to the party.
This is something the magazine testers always say about narrow bars. They love the aero gains and they feel comfy, but always the test gets negative marks for stability when climbing out of the saddle, or sprinting. If they also tried out some shorter cranks they might have a completely different experience, like i have.
I forgot to say amongst all this drivel that i am 6 foot with wide shoulders and i ride a mix of roads , farmtracks, and byways. I expect most bike fitters would have me on 46cm bars and 175mm cranks without going anywhere near machines that measure breathing, power output (not max but what can be sustained over long periods) and other metrics. I haven't got them either, but i know when i am not out of breath , how i recover from effort, and i can see average speeds increasing.
Last thing to say; i went for a ride today and everything felt spot on from the get go. There was no period of adaption so muscles have been re-trained :) . I am going to fit short cranks to the other bike now as that just feels plain wrong.
