Monkeeee01
https://velomotion.net/2018/05/assembly-story-orange-stage-6-tune-fast-foot-crank/
I’ve just fitted a Tune smartfoot crankset like the one below to my frame, and I had to tap the non drive side crank onto the axle with a rubber mallet to get it far enough into the axle - but now I need to remove it again!!!
It won’t just pull off so how do I remove it?
Obvious answer (and the one in the manual) is to tap it with a plastic hammer but with it being fitted to the frame there isn’t much room to get the mallet at the right angle to be able to tap it (even if I tap it at the pedal end).
Do I just persevere and keep tapping it at the pedal end or is there another way?
Thanks in advance
Thanks in advance
