Once A Hero
- Feedback
 - View
I’m struggling to fit a Syncros bar to a Syncros stem.
The independent shim should sit centrally in the stem, but try as I might I can’t open the stem clamp up enough to prevent the shim from closing up and stopping me getting the bar through whilst keeping the shim in the central position. It’s not a completely straight bar, but even the straight end part won’t fit through the shim whilst the shim is in the stem even without bolts.
Any tips on how I can open the stem clamp with one hand whilst feeding the shimmed bar in with the other?!?
The old coin trick won’t work because they are two clamp points.
