Hey guys,
As another project comes to an end I have some bits bought for it but not used and other I have no current plans for (always change but for now they need a good new home
Happy to post worldwide, postage is extra, or collection from near Warminster in Wiltshire:
1) RaceFace Forged chainset.
175mm arms.
94/58bcd.
ISIS BB fitting.
Real outer chainring gold 44tooth.
Middleburn middle chainring bronze 34tooth.
Shimano grannie ring black 22tooth.
Splines and threads in great order.
(I can sell without rings or swap the two larger for silver Shimano ones if preferred for a discount too).
£95 Arms SOLD
2) NOS in packet RaceFace grannie ring.
74bcd
24tooth.
(Marked 9 speed but I’ve used similar on 7/8 speed setups perfectly).
£18 SOLD
3) shimano UN71 square taper bottom bracket.
68mm shell.
110/111mm axel.
Sealed bearings.
Crank bolts included.
Smooth with good threads all round.
£10 SOLD
4) RockShox Judy FSX alloy brace.
Fits other Judy forks.
Slight crack as pictured, should not migrate as has stopped at the much more substantial part.
Hole for hanger (hanger not included but available elsewhere).
Comes with caliper spring mounts.
£28 SOLD
5) RaceFace XY Seatpost in black.
26.8mm diameter.
350mm post length (uncut)
Clamp parts all present.
£43 SOLD
6) GENESIS (modern but nice) inline black Seatpost.
27.2mm diameter
320mm post length (uncut)
Made by UNO
£10 SOLD
7) HOPE Tech3 X2 brake set.
Comes with a barely used 160mm floating disc, mounting bolts for the disc, rear caliper mount for a 160mm disc and front and rear mounting bolts.
Pads have life left.
Front braided hose is approx 850mm.
Rear braided hose is 1400mm.
Ready to fit but not used for a while so may be best with a bleed.
£100 SOLD
More pics on request, thanks.
175mm arms.
94/58bcd.
ISIS BB fitting.
£95 Arms SOLD
74bcd
24tooth.
£18 SOLD
68mm shell.
110/111mm axel.
Sealed bearings.
£10 SOLD
£28 SOLD
26.8mm diameter.
£43 SOLD
27.2mm diameter
Made by UNO
£10 SOLD
£100 SOLD
