Extending Kona P2 steerer tubes.
winjohn
I'm having a hard time finding a P2 fork with a long enough steerer tube for my needs. I am looking for a triple butted, threadless, inch and an eighth with canti bosses and they seem to be like hen's teeth.
I was wondering if anyone had any experience of welding a longer tube to these. I would have thought that any frame builder would find this a relatively straightforward job.
Any thoughts?
I've extended steerers, it's not ideal.
How long do you need the steerer? There's a nice 190mm pair of later susp corrected triple butted ones in the shop, good condition
Should be fine as long as the weld penetrates enough, a local engineering place will do it and turn it down in the lathe I'm sure. I've added a bit to a steel steerer in the past, and just used a grinder to get it flush. the part I added was between the lower and upper stem bolts so I didnt need to worry about getting it 100% smooth.
I don’t see why it wouldn’t.
Threaded forks, threaded headset, fit quill adapter.
Not sure how pretty it would be…
Really though, you either need an ahead fork with 230mm (ditch the spacers) or a stem with a slimmer steerer clamp, pull it down to 220.
I think an unseen weld in the steerer is undesirable, and a threaded setup inappropriate - surely it would be preferable to use a new straight fork or wait for the perfect p2 to turn up?
You're right, I could go down to 220 as a minimum. I like the look of the Synchros but it does have a big fat clamp and I have a hope stem that would work fine.
If a 220 fork came up for sale then I would grab it but I have yet to see anything bigger than 210 and I've only ever seen one of those.
I'm interested as to why you feel that a professionally done unseen weld would be undesirable though.
Out of sight, out of mind.
Not always good.
You can't be sure of the material properties across the weld, you are introducing a stress riser, and you might get unpleasant corrosion at that point.
Its probably fine, for quite a long time - but why would you introduce that if you didn't need to?
You can put a new steerer in a brazed fork, by replacing the whole thing.
Additionally brazing temperatures have a lot less effect (if controlled properly) on the material's properties.
