For Sale SOLD Joblot of parts £25 - Ritchey Marin Kiona SRAM Cannondale Suntour & more
Minifreak
SOLD
Joblot £25 plus post with Evri:
1) SRAM Impulse 3x8 shifters, work with Shimano too. In good order.
2) SR Suntour XCT Juniou triple chainset with matching RPM sealed bottom bracket and crank bolts, arms are 152mm.
3) Marin branded with yellow Kevlar corners saddle in good order, no damage.
4) Alpinestars quill stem for 1 1/8” steerer forks, 125mm c2c reach, slight rise.
5) Unknowm brand Seatpost in a gun metal grey, was on a mid 90’s Alpinestars bike. 31.8mm diameter, 330mm shaft length. Interesting and well thought out clamp.
6) Rigid silver fork, 4130 Cromoly, for a 1 1/8” threaded system total steerer to crown 157mm with 37mm of that being thread.
Axel to crown around 395mm.
7 ) Shimano 8 speed HG cassette with plenty of life left and HG chain.
8 ) Tranz X silver high rise ahead stem in 1 1/8”.
9) Ahead to quill stem fitting adapter, come with shims to allow use for 1” and 1 1/8” steerers/stems and mix of.
10) Cannondale black flat pedals, bearings could do with new grease.
11) Biscuit coloured grips.
12) Seat collar with quick releases, for 34.9 diameter seat tube.
13) lovely aluminium Bluemels bike pump with Schrader fitting.
14) collection of brake pads with lots of life left including a pair of Red Kool-Stops.
15) Ritchey Mega Bite Climb-Max tanwall, 26x2.1, good tread, walls are a bit dry but very usable after a clean.
16) Kona Mr. Dirt tyre, good tread,26x2.06.
17) Cheng Shin grave/road tyre 26x2.75, good tread.
18 ) Kenda tyre with Tioga Psycho tread pattern, 24x1.95x very good tread.
Let me know if you want more pics.
(Some bits on the table not included, only what is listed).
More pics:
Cheers,
not sure why I can‘t message you, maybe I‘m too new here?!?!
Do you send to Germany too?
I would take the crank then :)
Can you tell me the axle length please of the bottom bracket with the SR chainset, i've got something similar but have no idea what bb it takes.
