Hope Mechanical Disc Brake
Paul Torm
Anyone recognise this early Hope mechanical disc brake, I asked the folks up there and they couldn't identify it although they confirmed it was an early 90's example.
It is matched with this hub/disc.
Thanks
Thank you for that, the wheel is only 20" so not much use as it is anyway.
I still can't see the model in any of those pictures however it doesn't matter. It is also unmark, I assume the logo has been lost through time.
The logo might only have appeared once they were cnc machining.
If you take the bracket out, this silver front is close:
And of course the logo might have been on the bracket!
Iirc these calipers floated in the bracket to avoid rub.
Unfortunately I don't have the bracket, just the brake and the wheel/disc.
To be fair I'm not really sure what I'm going to do with them.
