- Feedback
- View
having a small clear out, prices include post, which will be recorded, which i think is now about £5
shimano Xt front mech, FD-M739 which makes it 8speed, 28.6mm top pull, pretty good condition, little bit of corrosion, could probably be polished to look better but i thinks is fully working, £20
2 Orange Stalk seatposts, 26.4mm 350mm, logos worn off, generally in ok nick, could do with a polish, both have lost the little rubber gromet where the clamp bolt is but it doesn't stop them from being used, £10 each, numbered 1 and 2, ONLY NUMBER 2 AVAILABLE
selection of bar ends.
mid 90's Orange bar ends, good condition, £15
carbon Token stubby bar ends, some scuffs but not bad, £15
i think WTB carbon bar ends, no logo, but good condition £25
onza ba ends, rusty, one rubber cover only, £12, powder coat and they'd look great
deore dx thumbshifters, bit beat up and one plastic cover is missing but they work fine £20
xt rear mech, quite beat up but i think it's ok, £15
sugino chainset, very good condition, 22/32/42, threads all good, rings good, 175mm arms £40
SOLD STUFF:-
shimano XTR M900 front mech, 28.6mm bnottom pull, very good condition £35 SOLD
syncros stem, removed from a Fat Chance Bike, 1" quill, (22mm) cewntre to centre length is 125mm, i'd say it's pretty good condition, has a noodle, only negative is the lasck of correct stem bung £60 potentially SOLD
suntour levers, work fine, bit beat up but fine £15 SOLD
tektro brakets, pads are partially worn but all parts are there £10 SOLD
kona brake levers, not sure if these are canti or v brake compatible, they do have the DR-Dew drilling for those bar end brake lever extentions if that helps identify them, £10 SOLD
SOLD STUFF:-
