For Sale Clearout Time - XTR, Specialized, Hite Rite, Magura, Royce, Shimano, Mavic
scant
Retro Wizard
shimano xtr m70 brake pad inserts. 8 sets (for 2 bikes) £15posted
Specialized Square Taper Bottom Bracket. very good condition. 68/120mm £24posted
24 Seven bar & stem. 1 1/8 ahead. 50mm long. £18posted
Hite Rite Spring, no clamps. £40posted
shimano deore mt61 u brake. missing plastic covers. £14posted
Magura Race Line. brake lever broken, spares or repairs. £18posted
Shimano Deore XT M730 with Campag big ring & TA middle & granny rings. 170mm arm. £29
Royce Crank Bolts. £18posted
Royce Titanium Bottom Brackets. both missing right cups. 102mm axle bearings are sound £25. 112mm axle 1 bearing is seized. £20
Kore stem. 90mm long, good cosmetic. 25.4mm clamp, 10deg rise. £14posted
SOLD Shimano Deore XT M737 SPD Clipless Pedals. bearings are smooth, can just about see the original logos. £20posted
Pace 50T /110mm bcd chainring. good condition. £14posted
Mavic Bottom Brackets. 116mm has 1 seized lockring, bearings spin but arnt smooth £14posted. 114mm axle has 1 seized lockring, bearings are smooth. £17posted
RaceFace XY seatpost. 30.9mm. 320mm long £26posted
Shimano Deore XT M071 Brake levers.. thats right, they've had the shifter mounts removed. lever blade paint touched up, main bodies pretty good. £17
Specialized 1 Inch Quill Stems. 100mm long with cable hanger £35 for all 3, or £15posted each
Shimano Deore MT60 drive side crank arm with full set of biopace chainrings. very good condition. 170mm. £24posted
Shimano Deore XT M730 Drive side crank arm. would benefit from a polish, otherwise sound. £20
Shimano Deore XT M095 STI SHifter / levers. some fading to the main bodies. otherwise sound. £26posted
unknown brand Titanium handlebar. 22mm clamp (no shims). 560mm wide. £20posted
Shimano Deore DX SPD Clipless Pedals. slight play in the bearings, otherwise sound. £16posted
Shimano DX Red left side brake lever. some scratches, otherwise sound £12posted
Shimano Deore LX M570 chainset. big & middle rings worn, otherwise sound £13posted
All items to UK mainland only. no overseas including channel islands
PM me for more info
