MattiThundrrr
Kona Fan
		Front brake cable outer, and outer at the rear derailleur are too long. I can't advise on English cable routing, always looks odd to me, I'm used to front brake on the left
			Yes that’s correct !Hi everyone, I've shortened the cables and will post pictures later, but now for the next job: sizing the chain.
Are the info in this video correct?
Does it shift correctly without any sounds knocks or anything ? At all ratios ? If so it’s fineNow, I cut the chain following the instructions on the video from Park Tool, but I think it's a bit long, so please advise.
These are 2 pictures with front largest cog and rear largest cog.
View attachment 865853View attachment 865854
And this is with front smallest cog and rear smallest cog.
I adjusted the B screw because the chain was rubbing on the derailleur jockey, but...
1. The chain seems slack and
2. The derailleur springs are all closed, giving no tension.
Same happens on second smallest cog, no tension in the derailleur springs
When engaging the third smalles gog, the derailleur starts tensioning
I never use the smallest front cog with the 4 smallest at the back and I know that it shouldn't be done, but this is against what the guy in the video says.
Do you think I should cut the chain a little more?
Bearing in mind that it will then be 2 links shorter.
Any advice much appreciated.
Please let me know if you need more pictures to make a judgement.
Thanks
