eightyeight
Beautiful Colnago C50 size 54 horizontal TT (which I believe is a 545mm top tube).
A mix of 11 speed Athena (levers and rear mech) and chorus (brake calipers, cranks and front mech). Wheels are nearly new zondas.
All is good working order just not getting the use it deserves.
It's not in perfect condition, has some minor chips etc. There is a crack at the top of the steerer tube, it's been that way since I had it 4 years back and is, I believe, from the previous owner over tightening the stem bolts. When I first had it the headset kept coming lose but I swapped out the steerer bung and that solved the problem. I've been riding it the last 4 years and it hasn't gotten any worse (the bung is correctly positioned inside the stem now too and I use a torque wrench).
It's in Bristol, might be able to courier at buyers expense. Message me for more details.
