Hope Bulb 12mm Bolt-thru axle and bearing
Good local lbs should be able to still get them from hope. I've sourced older from them before. Glad you got sorted though!
I called Hope the other week and they said they wouldn't have any left in stock as they are so old... Nearly had to sell my newly pitched wheel set (eBay find), but should be good to go once I get the axle installed and sort some end caps 🤞🏻
