I often accumulate random stuff that I don't need so I will add and remove things from this page over time:
All items are free and postage just needs to be covered. If you want more than one thing, i can combine them of course
postage mostly will be £3.50 for tracked 48h.
Items available:
SQLab 60X ergowave saddle, cracked base
Fabric Push-On rubber grips
Eccentric BB shell with shagged Shimano bb cup inside.
Cannondale lefty adapter to run standard 1-1/8" stems.
AliExpress carbon saddle, marked rear section otherwise little use, weights 90g. 135mm wide and 260mm long.
Fizik tundra carbon saddle, 260x125mm, 165g
OEM Whyte saddle
Specialized Flag cranks, 175mm
Cannondale lock on grips
Darimo ix2al stem, 90mm, -6 degrees, great condition, wrong size for.me.
Cannondale C2 alloy handlebars, 760mm wide, 31.8mm clamp unsure of other dimensions, looks to be 6 deg backsweep. = £8.
Renthal Fatbar carbon-lite riser bars, 740mm wide, 31.8mm clamp, 40mm rise, 6 deg backsweep, 5 deg upsweep. These have a few cracks from a customer overtightening their controls, ride with these at your own risk! = £8.
RSP alloy seatpost, 30mm dia, 400mm length = £5.
System-EX suspension seatpost w/45mm travel, 27.2mm dia, 350mm length = £5.
Universal kickstand M: Part for 20-28 inch wheels (2 available) = £3.50.
Ortlieb small top tube bag, damaged zip track on one side = £3.50.
Hope Floating Rotors, red, 160mm and 140mm = £1.50 each
Hope 183mm moto-mini rotor = £1.50.
SLX front mech, direct mount, triple = £3
Extralite QR skewers
Extralite Hyper lefty hub
Mavic Rear Ti-skewer 135mm = £3
Found more Ti Headset spacers 5, 10 and 15mm = £3 for all
Pack of 6 gold Ti flanged bottle holder bolts = £2
Tortec Expedition Pannier rack, used a fair bit, solid condition = £8
Sugino chainrings 22,32,42T with chainring bolts = £3
Generic PF30 BB = £3
Sram PG990 9-speed cassette and chain, well used, 11-34T = £3
White Shimano Front hub, 100mm QR with skewer and 180mm centrelock rotor = £3
Items available:
OEM Whyte saddle
