Mikey08
Kona Fan
		I do like that. Very clean, less is more look about it. Any pictures of your Trek on here?
https://www.retrobike.co.uk/threads...pair-and-restomod.465321/page-10#post-3504458
Thanks for the heads up, they are the metal type but currently they're quiet lol. I have removed a Phenolic or whatever they are called piston from an unserviced mini and it was a right pig to get out, It ended up in 100 bits!The brake looks to be in very good condition, but if the pistons are the older 2 part type(steel core inside alloy piston) as it wears its really prone to vibrating, which makes the most god awful squealing noise. The plastic pistons are a good upgrade for that and it will only set you back about 12 quid.
That is if the pistons are the first type, if plastic forget I added this bit.
Shame I hadn't spotted this earlier. I've a blue ano mini no3 caliper, would have blended in very nicely.
Just had a really quick look and wow!!! Loving your work, Very Dangerholm. Ill have a good read of your thread later.
