Wanted SRAM X9 9 Speed
MSYT
Hey folks
I'm looking for SRAM X9 9 Speed gear
- Shifters (Left and Right)
- Front derailleur (top pull - need to check clamp size)
- Rear derailleur
Thanks!
Hello MSYT,
Not exactly what you want but may be of use to you.
1) X7 9 speed shifter
2) X5 front shifter
3) X5 rear mech 9 speed
4) deore top pull front mech
There is virtually no difference between the X5,7 and 9 series
Deore front mechs are compatible with sram shifters and look virtually the same.
None of this will be of use if you are only after X9 stuff.
I’ve been running sram kit for 25 years and at 9 speed level it’s all much the same .
only the newer X9 XO are different.
Anyway ,upto you.
I've found the shifters, only found an x0 mech so far. I'm sure I've got x9s somewhere.....
Sram x9, 9 speed rear mech £10 if looking
I didn't even realise I had replies here! Didn't get the notifications somehow but the shifters could work thanks
