No, but you can take the rim off and replace it with one off another wheel. No straight forward but where there’s a will there’s a way.It’s not possible to repair a cracked rim like that is it?
It is just the rim that’s cracked not the carbon?No, but you can take the rim off and replace it with one off another wheel. No straight forward but where there’s a will there’s a way.
You need to heat the entire rim uniformely and carefully separate the bonding. Maybe you can do it with a heat gun. If you crack the carbon fiber lay-up in any way (not the resin but the actual twill), then you will have to do additional lay up in that area to reinforce the damage. Your next challenge is getting the carbon spokes onto a donor and uniformely bonding the two. The surfaces needs to be sterile and ideally a commercial-grade UV epoxy is used.It is just the rim that’s cracked not the carbon?
How would you remove it? I’m guessing it doesn’t just pop off…![]()
still for sale?Selling a front wheel in good shape been riding it without an issues. £150
Rear with a cracked rim ideal if you have one with bad carbon. £70
£200 as a pair. Postage no problem.
View attachment 714720View attachment 714721
