No worries. I suppose i should forgive youApologies! Didn’t see your post!
I have found an sram pg990 cheaper used, sorry for the bother![]()
I'm assuming that this is alloy, rather than steel? Is there any reason that it couldn't be used on generic, non-Shimano 110mm BCD cranks?Tiagra FC-4550, 34T silver, 2x9, 110 BCD = £12
It's not a Shimano crank specific chainring so as long as BCD matches and you want to use it on a 2x setup then you'll be good.I'm assuming that this is alloy, rather than steel? Is there any reason that it couldn't be used on generic, non-Shimano 110mm BCD cranks?
Do you also have 11/12-34 9 speed cassettes and chains in stock?
