Hadley GT rear hub service
d8mok
GT Fan
I’ve got a Hadley GT rear hub which has small amounts of play in the bearings.
This is the proper Hadley version to clarify.
Does anyone have a service guide ?
It’s fairly easy to remove axle ends and freehub body but after that it’s not obvious.
Cheers
If the bearings have been in there for some time, a bit more than gentle will be required.
A good close visual check should determine whether anything else is holding them in. If you can see the outer races of both bearings, then only friction is at work.
