Rock Lobster Team Tig SL Frame £50 Posted! SOLD
Racin'snake
Cannondale Fan
I bought this on the spur of the moment and has been hung on my wall since o needs to find a new home. It measures approx 16.5" centre to top so medium ish I guess. It is in used condition with many small marks and crazing to the lacquer bit no dints or cracks! It is very sturdy but only weighs 1.8kg. It has a 1 1/8" headtube and takes a 34.9mm front mech. Logos ok but replacements are on ebay very cheap indeed. The FSA headset looks unused. It takes disc or V-brake. It has blanks fitted to the v-bossed but some numbskull has rounded one of the allen bolts off so will require attention to remove if not using discs. If its a deal-breaker I will remove it.
It is a prime candidate for a fresh coat or will look good built up as is! I would like just £60 posted to mainland UK. Overseas at cost. Payment via PPAL FRIENDS/FAMILY OR ADD FEES ETC
Any questions please ask :-)
Rock Lobster Team Tig SLs are Tig-welded steel bikes. That's not a Rock Lobster, or a Team Tig SL, or Tig-welded, or even steel. You're a fraud.
1) This thread hasn’t been commented on in almost 4 years and is marked as sold.
2) Calling someone out as a fraud is a little excessive, even more so when you’re a new member of an established and friendly online community. Perhaps politely pointing out the error (if indeed it is an error, see 3) below) would be less accusatory.
3) Perhaps save embarrassment by confirming your suspicions before posting; at that time the Team Tig SL was built from Easton aluminium tubing. The Team Tig 853 was steel.
As a fan of rock lobster going way back, this is correct, 853 was steel and the SL was aluminium
