Wanted Sun BFR / Big Mammoth Fat 24" rims, Tioga Cube
coreygun
Trying to rebuild the bike I had in 2000, so I am after the following please...
-- Tioga Cube stem - 50mm length
-- 24" Sun BFR / Big Mammoth Fat rims, with plastic insert - There were versions with and without the plastic strip in the middle, and some were branded BFR, some Big Mammoth Fat.
Thanks
Remind me please how to spot the sport hub from a xc or bulb and will look
From what I can tell, the XC and Sport hubs are the same, except the disc bolt holes extend all the way to the spoke flange on the Sport. Bulb hubs have a different shape in the middle section.
I have actually just seen a Bulb for sale that also has the full length disc bolt holes, never seen it before...
Matched pair on mavic 521
32 hole f&r same as this second set on 317
Ah ok, how much is each set? I've also just realised that Sport hubs can't run a 20mm front axle, and the Z1 forks I've bought have 20mm. But, a Bulb can run 20mm. The main thing I'm really after is a black hub with those Hope stickers on them, as that's the bit I remember most from those wheels as a kid. So either it's new forks or a Bulb front hub 🧐
