BB spindle length?
goshow
Orange 🍊 Fan
Hi all, Is there a guide / science behind measuring the required spindle length?
I'm rebuilding a 92 Orange and the BB i've fitted looks a bit long. "fit a shorter one" I hear you say!! Obviously I'm going to but thought I'd ask to see if there was a guide / method for measuring the correct size.
Thanks in advance.
XTR m900 should already have a wider q factor, so going above 113 might make them sit too far out for your liking
107 is the standard M900 bottom bracket for a 47.5 chainline at the time.
113 if you need to go for the 50mm chainline
For a prestige or clockwork, the. 107 is your length, with recessed cups too.
Alu-O/Elite should be able to use the same as they only use middle diameter front mech bands. That and its what I use on mine.
