Lou Carpenter
Hello, I'm upgrading my crankset from a '99 Alivio, that uses the low profile square taper BB, to a '99 or '00 LX that uses the normal square taper profile.  In an effort to avoid buying a few BB's to see what worked I was hoping someone may have some experience with this.  Are the cranks going to sit a different distance out from the frame?  I was thinking if I bought the same spindle length then with the different taper the LX crankset would end up further inboard and so may cause clearance issues with the frame.  Any help would be appreciated, thanks.
