Bullseye cranks
Hi, not sure if this helps, but mine seems to be 126mm
Thanks, I wouldn't be surprised if there's a bit of difference between them but it would be good to know roughly what dimension (±) I'm aiming for.
I’ve taken another look and can get to 127 (and a bit). There’s a raised weld on the drive side where the crank joins the spindle, and on the opposite side the end of the splines is somewhat champhered/curved (I assume to help guide on the NDS crank) so I expect most measurements are going to be plus/minus 2mm.
