Advice please - suitable crankset
John Tarpey
Hello everyone. I have a Raleigh Maxim cromo 4130 (3 x 7) that I'm trying to restore. The group set is Altus ct-91. The derailleurs and shifters are fine as is the casette but the crankset needs replacing,(FC ct-91).
I have removed the bottom bracket which has cb-90 on it. It is 118 mm length, 68mm casing. Is there a crankset on the market that is compatible as I am struggling to find one.
Hope someone can help.
Thanks, John
Any square taper 7 speed crankset should fit mate. If you're after second hand put a wanted ad on here and you'll be offered plenty of options.
Thanks, John
what's wrong with the crankset?
Hi. Thanks everyone for your replies. A few of the teeth are damaged and generally worn. I will put pics up later. In work until 6pm. I had read that as well as needing to fit the axel length, a new crankset needs to be compatible with the shifters and derailleurs. Am I over complicating things?
