Musical instruments
I have zero musical talent. But the big boss (wife) plays Viola well enough to be able to waltz (see what I did there?) into pretty much any amateur orchestra. She also plays saxophone (preferring her alto to the more common tenor) and piano to a reasonable standard. Little boss (9-year-old daughter) plays the cornet/trumpet and can extract a tune from the piano.
considered an electronic kit? ... play through headphones ;)
Yes, though when they first started appearing i went to demo a Roland TDK and while i had a couple of hours of fun with the different sounds/kits, it just wasn't the same. The pads had no bounce or feel, the cymbals were still the weak point sound wise, i have played on a modern version the other year and they have definitely come a long way since the original kits, much improved feel and pretty convincing cymbals too, the price though i could not at the time justify for the amount of time i would actually play it now, though i am trying to get a friends dormant kit off of them, good cause and all that :)
I also looked into using triggers on a normal kit bitd, which makes more sense to me, though you are left with the same issues, noise or if using practice pads, a lack of feel.
  • Like
Reactions: enc
A couple of friends play sax, lovely instrument, though another that is hard to practice quietly :)
Tired of the thin tone from the weedy aingle coil pup on my '54 transition precision, so fitted a mighty mudbucker...
It now sounds like the sonic equivalent of being mugged! Just waiting for a switch to arrive so I can wire in some coil tap combinations, then its done.
Our drummer uses a Roland electronic kit. The sound is sensational, and he reckons you son't need to wallop ipthem so hard its good for unfit middle aged drummers.
  • Like
Reactions: enc
