2manyoranges
- Feedback
- View
hmmmm RJim that's a seriously laid back seat post and I can see how you have shortened the stem and carefully turned the bars to give a tiny bit more reach. Most droppers, as you know are pretty much in line, so you will need careful saddle selection to get a long railed saddle to set back a bit - they do exist but I actually figure that the WTB you have is actually one of them.
But for a cable operated dropper all you need is to constrain the outer....I actually see no mechanical problem in drilling a hole in the seat post for routing an internal dropper, then using a rubber grommet around an ovalised-by-file and touched-up hole. But you might not want to engage in that kind of vandalism. An external routed Reverb is a horrid thing. I have had desperately poor reliability from them.
A possible option for a cable operated dropper is these:
https://www.ebay.co.uk/itm/28400454...65qG4ErvhAXZPqGOrN_45auF8UODNhDMaAjrtEALw_wcB
or these lovely jobs
https://www.lordgunbicycles.co.uk/3...o20iWToOilsvZI3IMADTIpYAUZ2NS7H8aAlEgEALw_wcB
or you could indeed run section of outer and exposed inner with these:
https://www.sjscycles.co.uk/gear-spares/black-286-mm-origin8-clampon-double-frame-cable-stop/
what's your seat tube diameter for the dropper - I was looking for a COTIC SIMPLE at 27.2 and it was a nightmare trying to find an externally routed cable operated one of any quality (i.e. dependability and low weight) narrowed it down to a Thompson....ouch re price.....
