93? Klein Rascal Rekscue Project
There is a trick how to get a riser bar into a syncros stem. Put a coin or something metal inside and put the screws in on the downside of the stem, than you clamp the stem a bit open (because of the screw is pushing against the spacers or coin. Et voila it fits!
I feel like it will be impossible to open it enough but I will definitely try this, thanks so much for advice.
well same idea but from the top side. Tried from the bottom but the threaded insert were simply pulling out. So I pondered for a few hours while at work and determined to put nuts under the topside and press from there. Had to really open it up but worked flawlessly. 21F6F99F-7104-4E4B-82E1-BF7F5403F8D7.jpeg
Looking really mint! What do you think about the flanges at the outer ends of the Oury grips? I wasn’t keen on them and sought out the V2 version
Well to be honest I never really thought about it. I guess once I ride it I'll see if they bother me but aesthetically I may be unsure now that you've pointed them out 🙃
Sorry mate!
I was after some white ones - I uhmm’d and aaaah’d and just couldn’t warm to those flanges - so only choice I had was a V2 which hasn’t the range of colours - here’s the V2 in grey
