Wanted Girvin Vector ODS shock saddle washer
Joe*Pro
So I seem to have lost a curved washer off from the top of my pro-flex girvin fork.
Does anyone have a spare washer that fits the ODS link part ?
Thar cant be fixed. Shame really. If you'd like, I'll take them off you FOC (not that ill use them, honest). 😁 fancy measuring it up? I might be able to bodge up a new one for karma, depending if i have any delrin in.
Time to re kindle this original request, now the scammer with the unicorn washer for £1million has long gone.
i was riding the bike yesterday again and looking straight down the legs of the fork, the slight twist is really off putting so I figured I must try straight it out somehow.
Measured & ordered for testing, as per the photo hilighted size.
Will just then need to adjust the inner hole from 8mm to 10mm to fit the through bolt bearing tube that holds the top of the shock in place
If this doesn’t fit (might be too thick) then I’ll be sending the original over to you @novocaine for 3D copy/printing attempt.
