Withdrawn Clearout including: Syncros Control Tech Shimano XT Amoeba Middleburn Sakae USE Marin THREAD CLOSED
Shimano and Suntour front mechs now SOLD.
Before the day's out, I'll be updating the thread with several of the other promised (and a few others) bits to be sold, if anyone's interested...
UPDATE FOR NEW PARTS:
Shimano XT BR-M739 v brakes.
Very nice condition except for a couple of knocks here and there. Logos still very clear. Only one set of the pads are original but both have lots of life left. And two of the frame attachment bolts aren't original. All threads are good etc.
£40>>>£35
Shimano XT BL-M739 brake levers
Also very nice condition for these. A couple of light scuffs can be seen. All threads are good and pivots are still very tight.
£40>>>£35
GT bars
Very nice condition with only scuffs from fitting stuff to the bars. Length is 60cm and clamp diameter 25.4mm.
Lazer etched logos are nice but not too obvious.
£10>>>£7
USE seatpost with shim
An OK condition one of these seatposts. The matt finish has worn off a good deal where its been inserted in the frame and is also a bit tired looking above this. There's no insertion scoring though. The USE sticker is also not great. The saddle cradle has a scuff on one of them. Nothing is bent and threads are all good. One of the bolts isn't original. Diameter is obviously 25mm. The shim came with the post but I'm not sure if it's a USE one. I think it converts the post to 27.4mm size but not too sure (came fitted to a Pro-Flex 953 if that helps).
It's been cut down and now measures 30cm from bottom to the top of the cradle.
£20>>>£15
Titec seatpost
Pretty minty condition and I reckon this is NOS as there's no wear I can see, although the post has been stored without packaging so not 100%. Length is 36cm from bottom to the top of the cradle. Diameter is 27.0mm. All threads are good etc.
£15>>>£12
10/7/21 UPDATE FROM HERE:
A Vuelta USA chainset with self extracting bolts
Quite a nice example of this chainset, although the ano finish is a tad sun faded on the front sides, plus there's also a slot cut into the rear of the driveside crank from where I assume someone's made a slot in the pedal fitted to help with it's removal. It's not too bad though and I've ridden it with no trouble. Apart from that there's a couple of knicks and scuffs but it's still v presentable. Chainrings aren't original- outer and middle rings are Shimano alloy ones, and the granny ring is a new Onza steel one. Threads and tapers all good. Ratios are 42/32/22t. Crank length is 175mm. These chainsets aren't seen too often (I've never seen another one) and it's all about CNC'd perfection:) Also, would be well matched up with the same era Vuelta saddle I listed in the thread earlier.
£50
NEW THREAD UPDATE FOR THE VUELTA CHAINSET MENTIONED IN OP. ADDED TO THE END OF 2ND PARTS LIST. WILL ALSO BE ADDING THE XT CANTIS MENTIONED SOON.
Can I please cheekily ask for dibs on the titec post until I can check the size I need? I know it’s either 27.0 or 27.2.. Only a few hours..
