Pm sentGot a brand new set of 1.8s. They are much wider than the size suggests.
Cheers, that would be great to see if you have any images..... Are you selling the Splashback's?Strange, can't reply to your pm, says the conversation is locked.
Anyway, I've had 1.95 smokes and the 1.8 splashbacks side by side in the past and the splashback is wider. I have a set on a build currently (dynatech torus) and they fill the stays nicely. I can grab a pic if you want to have a look (build has been pillaged for a few bits so not complete, no forks for example).
Thanks, that’s really appreciatedHere are some pics. Fortunately it was hanging next to my team rts which has a spesh ground control (or similar) in 1.95 so you can compare the width. The spesh tyre is fully inflated, the charge is low on air so would look a bit wider when inflated. They look practically the same to me as pictured.
The set pictured has had a ride round my local park on tarmac, I have another set still in packaging/never used.
