Just re-read your original post and realised that you are using the rings from a Ritchey 2x9 set up on a triple chainset, is that not where the problem lies? I'd guess that they were never designed for triples and in the Ritchey 'save weight' approach they shaved it down as much as possible.
If you do want to use the 2x9 then why not try the 1.2mm spacers before getting anything too expensive made up, or find yourself a 'normal' sugino middle ring (didn't they make the Ritchey ones?) Have fun with this one!
