What cassette lock ring do I need for Campag Electron Rims
petmcgratt
Hi there, I wonder can anyone help.
I bought a pair of Campagnolo Electron wheels with record hubs last week and need to fit a 9 speed campagnolo cassette. I think the Electon wheels are from year 2001/01.
So I bought the 9 speed cassette - Veloce ultra drive 9 spped 13-26T with the following lock ring:
CS 401/R1 023 for 12, 13, 14 Tooth cassettes. Unfortunately this lock ring is about 1 mm too big and so I can't screw this into the threads.
Can anyone tell me what lock ring will let me secure this 9 speed 13-26T cassette to the hub? It must have to be slightly smaller in diameter to the one mentioned above.
thanks
Peter
I had this exact problem a few years ago , basically you need a M26x1mm threaded lock ring which Campag used on Electron wheels , the lock ring you have is for modern Campag M27x1. I could not find a Campag one anywhere at the time, but was able to buy a Marchisio one code is GMC11 (11t up) or GMRCL 12t or13t up , should be still available ,trade importers are RSI 02089652510 they will tell you your nearest dealer.
