mattr":14jm9giv said:Actually, looking closer, is that spacer removeable, or is it threaded onto the axle, cos it looks to me like the lock nut (its slightly tapered).
In which case, the wheel hasn't been fudged and any 126 OLN should fit, either with the freewheel you have on there (which is 28mm wide?) or the 6 speed.
I think there is a locknut there as well. So does that mean its threaded onto the axle, as the other hubs for sale don't seem to have the space for the spacer.
See this thread
viewtopic.php?f=22&t=278909
where the hubs don't seem to have enough space.
So if I get another say, dura ace 126mm hub, fit on a 6 speed sprocket set, will I need to get some spacers or should it be plug and play?
And if I do get spacers where do they fit?
Am I also correct that there is no way a 130oln hub is going to fit as there is not any axle left for spacers?
