Record and Chorus 10 speed parts
Hi,
I will take both the Record 1" headset and bottom bracket if they are still available. I can pay immediately.
Thanks, Steve.
Hi
I'm interested in the following if they are still available:
chorus shifters
chorus rear derailleur, alloy
chorus front derailleur
Interested in the carbon rear mech, I need to double check what gear range it'll cope with though (unless you happen to know or it's written on the mech?!). Could I have a short dib please? :)
Nominally the capacity is 27 teeth and the maximum cog size is 26. So 53-39 with 13-26 block or 50-34 with 12-23 block.
In practice you can get a bit more out of it. I've used a short cage with 53-39 and a 12-27 block which is a capacity of 29 teeth and it's fine. Doesn't rumble on the 27 cog either.
Thanks guys, that's great info. I failed miserably getting that off the Campy website in my lunchbreak!
Sadly it'll be too strained for the kind of ratios I've got fitted, and I'm not man enough to up the inches I'm afraid!
Thanks again for the help and info though :)
