Wanted Bullseye rear hub washers and front hub axle
Ingmar
Hi folks,
I am Looking for original Bullseye washers for the rear hubs. Further, I am looking for a single front hub axle.
Best wishes Bertram
They’re a fairly standard size, it should be printed on the plastic cover, I replaced some recently but can’t recall the details. There were no special ‘Bullseye’ branded bearings as far as I know.
Hi mates, thanks for the clarification. I agree, every standard 6001 bearing will do its job. However I want to have the original ones anyways :)
Original bearings I know of were from FŁT4 (Polen, black) and GBC or General Bearing Corporation (US, orange).
Still looking forward to take your old bearings :)
B
I do/should have some washers from a 126 or 130 rear axle. I need a 135 so these are surplus. I might be able to help with the bearings but not sure till I check. PM me if interested and I'll have a look when I can
Thanks for the hint! However, I am looking for the original steel version in 1.2 mm thickness.
The search is still on :)
