XTR M900 rear hub - needed for parts
fatchanceti
Trying to salvage an old XTR/231 wheelset. Upon receiving it the drive side on the rear wheel was not in good shape - cup and cone both damaged. Non-drive side is fine.
So I need a freehub body (M900 or something that is compatible) and a drive side cone.
Anybody have a cosmetically rough, but functionally good FH-M900 rear hub that they want to part with?
Thanks.
Thanks for the note. I have sorting pondered building up a resto mod wheelset for this bike using some modern tubeless compatible rims and in that case that hubset would be pretty cool. But first Id like to salvage this set if I can. Ideally it would be great to be able to scavenge compatible parts off another hub, but it seems that in some case XTR uses it's own proprietary parts.
edit: sorry guys, I've updated my profile a bit. I'm US based - so probably won't be doing a lot of shipping back and forth of wheelsets - hence my desire for a donor hub (or even info on what parts from other hubs) to get this back together.
I've thought about going CrossMax - which might be a bit new for this particular frame, but not overly so. It's probably a strongly mid to late 90's unit.
If you want a more modern wheelset: My mate has an excellent set of Mavic Crossmax (2nd or 3rd Generation) for V-Brakes and tubeless tires, allready fitted with expensive new Schwalbe tubeless tires. If you are interested I can get you pics and check weight (probably verly low) and price (around 200-300EUR, I guess)
