Sturmey Archer drum brakes/parts of (36H)
ffoxy99
Hi.
Does anyone have any of these in steel rather than alunimium.
There were a bewildering array of them with names which don't immediately indicate what the differences were but they all seem to be thin on the ground on the second-hand market.
The rears were
  • SAB3 - like an AW with a 70mm drum brake on the left
  • SBR - another 70mm one but on a single speed hub. it seems to share all its brake components with the SAB3
  • BR - a 90mm drum brake on a single speed hub for use with rod brakes
  • BR/C - cable operated version of the BR
  • AB - like an AW with a 90mm drum on the left for use with rod brakes
  • AB/C - cable operated version of the AB
up front we had
  • SBF - 70mm hub brake
  • BF - 90mm hub brake for use with rods
  • BF/C - cable operated version of the BF
Looking at what I've just written it seems that:
  • S = small (70mm)
  • F = front
  • R = rear
A = rear 3-speed hub
  • C = cable
  • B = hub brake
It is confusing however as there is no indicator for rod, and rods are rare now but back then it seemed more necessary to show C for a cable operated part. I suppose if R was used for rod they'd need something new to designate rear..
