Lots of parts inc Thomson, Fox, 10 speed gear.
hedgehog
Devout Dirtbag
All items include postage to UK. Paypal or bank transfer only.
Thomson Elite X2 stem, 31.8 x 100 x 10degrees. Excellent condition.
£35
____________________________________________________________________________
Thomson Elite seatpost. Cut to 315mm from saddle rails. 31.6mm. Very good condition, usual marks from use on shaft.
£38
Fox F100 RL forks. 9mm dropouts, 170mm x 1 1/8th steerer with star nut. Rebound, air spring and lockout. Post mount. Good condition, functionally spot on. Few marks to the lowers, and some faint surface scratches to rh stnchion. Slight cable rub on revers of crown. Seals and bushes tip top, no leaks.
£205
Fizik Gobi XM saddle, with Kium rails. Tail/wing flex, carbon reinforced hull. Superb condition.
£55
Shimano XT M773 long cage Dynasis rear mech. Brand new, unused.
£44
SRAM X7 and Elixir 5 with Matchmaker clamps. In superb condition, hardly used, with just very minor marking from fitting and minor use. 10 speed shifters. Include 2 x 160 clean sweep rotors, IS rear bracket, all tri align bits, and rotor bolts will be thrown in.
£155
Or will split (but you will need to get the shifter bracket - the brake will still have the clamp, but is Matchmaker one with the extension)
SRAM X9 Ten speed rear mech. Hardly used, superb condition, couple of minor marks. Long cage.
£43
Crank Bros Candy 1. Excellent condition. Boxed, but no cleats.
£25
Shimano SLX HG81 cassette, 10 speed, 11-32. Unused.
£35
Shimano SLX HG74 chain, 116 links, unused boxed.
£20
