Lights, lights lights...for Mayhem....10W dual LED
Gerard
......these look quite good and only £20 of your finest British ponds sir.
https://www.planetx.co.uk/i/q/LIJOBBB10 ... ront-light
The Jobsworth Burn-Baby-Burn uses a pair of 10 watt hi-power, hi-efficiency CREE LED's to deliver 700 lumens of light power. With dual LEDs it throws a wider beam pattern than the single LED Torrent making it ideal as a commuter light or to use alongside a super high power main beam for serious off-road activity.
A powerful 4800mAh battery pack running at 8.4v guarantees long run times and of course everything is weather sealed to keep the weather on the outside where it belongs. We've packaged the Burn-baby-Burn with the small battery pack to keep costs down and make it more affordable for all cyclist. If you want run times longer than any bike ride there's a 10,000mAh upgrade battery available.
Specs:
3 constant and two flashing modes. Click to swap, double click for flashing
Run time: Hi 2.5hr, Med 4hr, Low 8hr
Battery: 4 x 18650, 8.4v, 4800mAh
Weight: Head unit 95g, Battery 188g
Bar mount: O-ring
Power: 700 lumens
Construction: 6063-T6, anodized body
Weatherproof: IP65
pensier
Looks good. And what about tail light? What can you recommend? I found several variants from MicroBot, but still it is hard to choose. Is it good brand? What devices do you have? Thanks in advance!
