Takingabreak
Dave Yates Fan
- Feedback
- View
Something like this might get you started but I tend to find that I can find better tools on a one by one basis, which if you plan to be a serial tinkerer would be better in the long run
I think that is what it is.Sugino cranks sometimes have a threaded bolt behind the crank arm that doesn't require the slotted female bit.
Personally I wouldn't use spacers to plug the chainring bolt gap. You can get a set of the right sized bolts for not much money.
I'd also not bodge tools for the cassette locking. You screw the teeth, you aren't getting it off easily. You could use a pin spanner but that's a tool in itself. A proper tool won't cost a lot, if you buy one of the cheap tool kits, you'll get cheap tools but at least they are the right tools.
