Chris king hub axle conversion help.
Luke26mhz
Any Chris king hub experts on here?
I have bought myself my first ever pair of kings, iso front and rears.
The front is 20mm through axle and I’d like it to be q/r instead.
Can someone point me in the right direction of what axle conversion kit I need please?
Unfortunately it's not so easy .. there are two kind of CK ISO front hub : the LD ( big body ) and the SD ( small body ) . You also need to know what generation they are ( see the laser printed serial number and go to the CK website ) , so You can know the correct conversion to order , but unfortunately the old generation' s spares are not produced anymore . The SD hub need also to buy a new clamp ring , specific for the 15 mm shaft , while on the LD the same clamp ring of the 20 mm shaft can be used .
  • iso_hub_specifications_wheel_building_information_2018.pdf
I think to have two complete QR shafts 1st and 2nd gen. , but I guess they should be for SD hub only . I will be happy to exchange with a 20 mm , if they will fit .
