Campag C Record Triple?
This from the 1990 catalogue. Triple in Xenon and Athena only, not Chorus, Croce d’Aune or Record. 170mm crank length only by the looks of it. Hope that helps.
Although you do see quite a few "home conversions" with holes drilled to take a smaller ring on the spider arms - a popular "conversion" in the 70s
You could probably make one like the NR by drilling and tapping the arms and adding spacers for the smaller inner chain ring. I believe when people first did this to the NR it was just done by people that knew a machinist and had them do it. I'm pretty sure it would be fine as there's more meat to the arms than a NR crankset. I bet it would look sweet.
