1976 Crustnalgo Super - a project
PhillB
GT Fan
I do love my old British Bikes, but I also have a soft spot for Italian ones too. I've tended to avoid the 'big names' (mainly because they attract a massive brand premium to the price) But I am always interested in one that needs saving. So, as a result of a late night random search online this now one joins the project queue.
It's a rusty old Colnago Super. I think it is a 1976, might be 77.
It was a bit of a gamble, as I bought it unseen but it made me smile when it arrived.
I really don't know much about Colnago as it was not a brand I ever expected to own to be honest, but am learning rapidly.
In my experience, whilst rust is rust, there is a difference between a much used bike that is rusty through wear and use and one that is rusty through neglect - unfortunately this is the later. I understand it has not been used for at least a decade. Given that there were spiders under the saddle and in the fork steerer when it arrived - I suspect it was in a damp shed. The kind of rust this one has comes from the repeated condensation cycles and poor air circulation you get in an old damp shed. The bad news - it is every where, the good news, it is all surface....so fingers crossed, I should be able to get rid of it... although the bits on the fork crown - not so much... we'll see.
Still, the good news is that it will have another chance to shine again! Although it might take a little while.
As you can see tyres are shagged. Straight in the bin.
I am a sucker for pantogaphed bits, which as they are Alloy will clean up nicely with some elbow grease.
Somehow it ended up with Suntour components on it - it also has a GB handlebar and Weinmann brakes and levers - odd.
Hubs are Campagnolo Record though and should clean up ok with some work 🤞
The spokes are screwed though, there were chromed it seems but the rust has burst through the chrome plating! Rims are Mavic and might be salvageable.
Saddle is not ripped, so I'll try to bring it back to life too...
To be continued.....
That's an early model Laprade seat pin. If you've never seen one before you may be surprised when you discover how long it is compared to others from the same era (late 70s/early 80s). Hopefully it's not stuck because there's a lot of it.
I had not seen one before...and it is indeed long !!! To underscore my theory about the rust, everything came apart relatively easily...it's clean inside the tubes :)
A bit of an update on the Crustnalgo...
This will almost certainly be my fourth and final paint job of 2025. It took a while to strip right back and get rid of the rust - it was all surface, but it was everywhere - inside of the tubes seem fine though.
As much as I like the bright metallic green, as I was stripping anyway I decided to go with something a bit different (to my other bikes anyway) After a few coats of etch primer it was time for Kustom Canz Metallic Ice Blue. It's a bit less blue and a bit more ice than the photos show.
It'll cure in the shed for a few days now...
