For Sale GTTurbo's clearout - more added 19/10/25
gtturbo
Lots more to come but here is a start of the parts I will never use. Some are also on ebay but listed cheaper here. Prices exclude postage and I will post at cost via the courier of your choice. Happy to take paypal f&f or if you cover the fees goods and services. Can also do bank transfer. Please just ask for more pictures of any item.
One pair (front or rear) Campag Olympus ? cantilvers with bolts and springs etc. Pads are not original £15
A rather tatty Rolls saddle. Someone might want it to recover I guess. £4
Deore DX ST-MO75 STI's. Work ok just look a bit tatty. £18
Fred Salmon bar ends ?. £4
Deore LX M550 cranks arms 175mm. Extractor threads a little worn on drive side but the tool still screws in correctly. £9
Orphaned Deore.LX M563 drive side crank arm 175mm. £5
Tioga stem 1"1/8 ahead and 31.8 bars. Approx 80mm long £5
Saracen handlebar 1990. 600mm wide 10 degree sweep. £10
Club Roost IDB150 bar. 580mm wide and 5 degree sweep. 165grams according to the blurb. Small indent one end from an overtightened bar end £4.
Carbon Easton Monkey Lite SL CNT bar. 610mm wide and a little rise. Lacquer starting to bubble in places here price. £14.
1990 Diamondback Axis XT frame. 18" c to c or 19"c to top. Cosmetically rough and the seatpost is stuck. Bought to restore as I had been looking for either an 89 or 90 for ages. Typically a few days after getting this I got a complete 89 bike. Despite its faults still a bargain I feel at £25 for a Tange prestige frame. I can box it up and you can arrange your own courier to collect.
X-tas-y 1 1/8 ahead stem. Approx 120mm. £4.
Profile design road stem. 1 1/8 ahead. Marked 110x72 degrees. £8.
Deore XT m751 front derailleur 28.6 bottom pull £8.
27.2 black seatpost. Believe it was originally from a Specialized ?. Nice condition. The shaft is 330mm long £9
Alivio 8 speed rear derailleur. £4
Marin Lite quill stem 1" or 22.2mm. For 25.4mm bars. Some rise and approx 120mm long. £4
Shimano BR-T4000 V brakes front and rear. Bolts included but no noodles. One pair has some green overspray that should clean off. £8
Avid 20 V brakes. Front and rear. Need a clean. One pad insert is missing the small pad retainer pin. £4.50
Another set of Deore LX V brakes. Front and rear with levers. Pictures in the 6th reply below. These are the silver.canti ones, the black ones pictures in an earlier post have sold. Need a clean and new pads. Mounting bolts included. £17
Rockshox J4 forks. Lockout works but the u turn adjuster doesn't appear to be working. As I would caveat with any suspension fork they seem to work ok but would no doubt benefit a service. Steerer is 1" 1/8 ahead. Its been cut wonky by a previous owner. Taking that into account once you cut it straight the steerer will be approx 180mm long. For disc or cantis. £30
* See Page 2 for pictures of the items below
Zipp 24 hole rear hub with a Campag freehub. OLN is 130mm. Came off a 404 wheel as I need a Shimano freehub and got a great deal on a Hope RS4. £22
Suntour 28.6 front derailleur bottom pull. Sorry I dont know what model it is.
Avid SD 1.9L brake levers. A bit scuffed but wok fine. I will also include for free the one wheels worth of Acid 2.5 v brakes. As per the picture one arm is badly faded compared to the other and no pads. £8
XT RD-M737. Rider condition. The jockeys wheels are worn out and needs a clean. £6
Deore DX cantis. One pair. Fixings have a little rust and the Aztec pads are worn. £5.
Specialized body geometry lock-on grips. Lighly used but a little dirty. £5
Cateye wireless speed sensor. Came fited to the forks of a road bike I bought. I use Garmin so it's of no use to me. Just cover the postage and you can have it.
SOLD Alivio SL-M410 3 x 8 shifters. Good working order. £9
SOLD Cannondale grips. Might be called Calamari grips?. £10
SOLD - Deore DX long cage rear derailleur. Nice used condition £14
SOLD -Deore LX v brakes.and levers f&r (little bit of rust on steel parts of cantis) £24
SOLD - White Industries 175mm left hand crank only. Probably regret this one as I think I have an orphaned RH somewhere. £15
SOLD - XT M735 long cage rear derailleur. Rider condition £8
SOLD - Look PP166 pedals. No cleats. £8
SOLD - Border riser handlebars. Nope I've never heard of them either. 31.8 clamp and cut to approx 600mm £4.
SOLD - Team Saracen by Bassano saddle. Nice used condition. No rips or tears. £5.
SOLD - Deore DX front derailleur 28.6 bottom pull. £5
SOLD - Shimano CS-HG200-7 cassette 11-32. Hardly used, see pictures. Came on a bike I bought but I swapped it for something period correct. £5
