Sorted Pace RC 30 1 1/4 threaded. Fork or crown/steerer
Tomac23
Hello everyone. I am looking for a Pace RC 30 fork for my Orange Alumnium O. Needs an 1 1/4 threaded steerer and approx 160mm steerer length. Might be a tough ask. Does anyone have anything?
Cheers
Sadly, I can't help with the 1-1/4" crown, but can make up the steerer if you find one.
All the best,
Thank you. I think I’ve found a crown so I’ll message you about the steerer. Cheers
Would be interested in seeing some images of RC30 1 1/4” … briefly wondered if I had one but , think much more likely is 1 1/8” as that’s the steerer am running in it currently.
Looked online but difficult to discern differences from images have seen.
GLW project
Corrected by @justbackdated below :)
The 1-1/8" and 1-1/4" ones share the same crown [are]
It is identifiable by the bulge in the front and rear faces:
[On later models] When running a 1-1/8" or 1" Ø steerer, there are step-down shims incorporated into the headset crown race. This is omitted when running a 1-1/4" steerer.
The 1"-only crowns are flat-faced front and back:
All the best,
Awesome thanks for detailed info @danson67 … was wondering if that was the case…there’s a 1 1/4” : 1” shim being offered on @justbackdated ebay sales page…with this new knowledge might have to consider getting that part in stock.
For reference here are my RC30s + 1 1/8” steerer tube + CK crown (since removed to reveal the Pace shim / crown race part described above)
The original RC30/35 crowns were made with steerer socket sizes to suit the steerers.
They were produced with:
1”
1 1/8”
1 1/4”
Indeed, as Danson points out, the 1” easily spotted with its flat face. The 1 1/8” and 1 1/4” had the bulge in the face, the 1 1/4” was obviously larger/wider. The crowns had a well on top into which the lower flange of the crown race collar would fit. On later crowns this was omitted. Reducer shims then introduced could allow smaller steerers to be fitted in the two larger size crowns
Later, notably in conjunction with the release of the 1995 RC35 MXC/D fork with its 1 1/4” steerer socket as standard, reducer shims were required to allow fitment of the two smaller steerer sizes in the crown.
In 1997 with the release of the RC36 all crowns went to 1 1/8” steerer socket, a reducer shim still allowed 1” steerers to be fitted, but that was the end for 1 1/4”
@Tomac23 - a bit late to the party.. but I have a NOS 1” RC30 crown if of interest. I bought it direct from Pace who had it in their stores. Best wishes
Very informative thread to read, thank you!
I’ve an RC30 (2nd Gen) with 1” crown - if I wanted to run a 1 1/8” steerer, I assume this means getting a 1 1/8” crown?
