Frankenorange
Orange 🍊 Fan
		Regarding old school minis i have always preferred a super revvy engine with 80-90ish horsepower. lightweight engine internals, super light flywheel, quality clutch, and a cam and carb combo that picks up quick sharp and revs on. Programmable ignition is the way to go instead of fecking about with springs and weights in the dizzy.
Mate that to a close ratio box with LSD and job done. No mega big valve heads, offset bores, and race cam trying to get the big bhp numbers. Also makes it super cheap engine wise and it will last longer and be reasonbly economical. Keeping the bhp lower keeps torque steer to a minimum as it is tiring and can be dangerous.
The place to spend the big money is on the suspension and brakes. The old mini is the perfect base for using modern super adjustable coilover dampers and anti roll bars. Quality discs and calipers up front and good old fashioned minifin drums at the rear. They dont need anymore than that at the back but some re-engineering to accept some tiny single pot discs would be ok. Way to easy to over brake the rear end.
The old mini is a B road and country lane weapon. Get it up to speed and just keep it there as much as you dare. You will get your arse kicked by alot of cars on a trackday but in the right hands a cleverly tuned and sorted mini can hold its head high on more challenging roads.
		 back lanes, nothing came close, including a golf and a 205, on a wide road it was scary as hell.
