There was a fashion in the 70s? for "Ankling", pushing your toe down on the downstroke.
Cuban heels perfect
And then Greg Lemond did the heel of the foot down almost dragging on the tarmac in the mid-80s.
Cuban heels perfect
What about the 'Lucidone Eccentric Pedal Easy Reach' system? You can keep those retro cranks and dial in your perfect crank length with the fully tunable LEPERĀ® system with its simple eccentric pedal spindle.
I'm also launching on an even more radical system based around an adjustable elliptical crank system, the 'Lucidone Easy Elliptical Crank Helper' - forget Biopace, now you can pedal in an ellipse and create 300% more power, 800% more efficiently and nearly 0.1% faster with 'LEECH'Ā® technology.
Introductory offer from all reputable TV shopping channels must end soon!
Usually long cranks exacerbate knee trouble because there'slwer cadence with greater force at higher "knee angles" - the larger diameter of the pedalling circle reduces rpm at a given "foot speed"I also found the few sets of 170 mm cranks I've tried uncomfortable and actually got knee discomfort from long rides with them - could have been another factor in there though. I haven't done back to back comparisons with longer length cranks, but I have afew sets longer than 175 which I find comfortable.
