doctor-bond
Feature Bike
		So, notes to future self:
Don’t leave the dishing too late; fixate on one variable and the others sneak off while you aren’t looking.
If the nipples are less than finger loose, then they are not going to be exacting any force on the wheel. Tighten them to only just finger tight with …. your fingers. Using an electric screw driver is too wild, doing it one turn at a time will drive you mad.
Where you have a dishing gap, it’s the rim that moves, not the hub - double check you’re moving the rim the right way (especially if you a have a lefty loosey righty tightly/ east west issue )
If you don’t (yet) have a truing jig and are relying on an old fork, chose one without ‘lawyer lips’, or file the fuckers down.
For dishing, find a nice doughnut shaped rest to place the wheel on. That expanded styrofoam one over there behind the box in the corner looks ideal ….
All spoke length calculators are not the same; try and get a cross reference for the hub and rim data you’re relying on.
Keep going and don’t overthink it.
)If you don’t (yet) have a truing jig and are relying on an old fork, chose one without ‘lawyer lips’, or file the fuckers down.
