I would highly appreciate if anybody could help me identify/find this bashguard.
It might be from Monty’s, i am not sure.
It’s gotta be a 94bcd 5-bolt.
Am stuck finding something that fits and though the one i have would do it’s job, it would look all sorts of wrong:
Please help to save this build from being utterly uglified by my incompetence!
Thank you for chiming in!
There I was thinking, there were only Middleburn bashguards proprietary to their own cranks, but thank you, so there are bolt-on ones? Off to the list for my first wanted-post.
You can always just get a similar sized chainring ( with the same BCD) and turn the teeth off of it. If you don't have the lathe & skills, try to find a local machine shop or even better a hobby machinist to do it for you. It would be an easy quick job.
Thanks Lads!
Yeah I’m loving the idea of making it work with something I have. Either a chainring or this bash.
Tried finding a spot where the thin part makes most sense. Unfortunately it won’t go behind the crank arm as this one is originally intended for one with no hidden bolt and the crank hast the 5th bolt under the arm. thinking top front when my chocolate foot is forward. Sanding and drilling sounds like a lovely idea. Thank you!
Hi,
before you invest some efforts, time and money (tools) into building something on your own, I would like to just comment that the bashguard used at the nice Cannondale picture above is not so special.
Just search for a bash guard for a Trial bike.
E.g. Onza has it Armstrong bash guard or even complete cranksets with BCD94 including a bash guard
(this is post Onza Retrobike peak times, rather stuff from this century from what ever is remaining from this former iconic brand)
Some of those trial bashguards like the one at the Onza cranks from what i can see also at the Cannondale bike, are protecting very small change rings (<30T) mounted than on the inside of of the crank (not the middle position with 94mm BCD but the 58mm inner position).
So if you want an bash guard exactly like the Cannondale you have to run also a very small chain ring only.
